I have detached garage which has no electrical panel, but has 3 lines run to it from the main house panel. There is 1 120v (20 amp I believe), 1 240v 30A, and 1 240v 50A. I am really in a need for more 120v circuits. Is it possible to use one of the 240v lines to route to a new panel in the garage, and from there, a few 120v 20A and 1 or 2 240v 30A circuits from this new panel? I would just use metal conduit for all of the new lines, and use the existing 120v only for lighting. FYI, this is all original wiring from ~1978. I am pretty sure the 204v 50A line is 2 conductor plus a ground. Could the ground be used as a neutral for a new sub panel, and then add a ground?
