TX63CONV
I have an 18’ enclosed car hauler that I would like to add 110v power to. I would like to be able to plug into a standard outlet at the track that would power my trailer for the following:
(1) interior lighting--I was considering a small 24” or possibly 48” fluorescent switched garage light in the center of the trailer.
(2) I would like to power a portable A/C
(3) I would also like to power a medium size 40” or so flat screen TV, receiver, and satellite.
Obviously, I could haul the trailer to my RV shop and let them handle everything but I feel relatively comfortable around wiring and this site is such a good resource.
My thoughts were to cut a hole for a weather proof receptacle on the driver’s side bottom rear, wire it to a breaker box inside and then run wiring for the overhead light, and a power strip at the front for TV, Sat, and A/C. I would also like to have the ability to plug into a generator if there is not a power source at the track.
Where I think I would have trouble is (a) determining load, amps, etc as I could possibly have all of these things running at the same time (b) wiring the breaker box and (c) sourcing parts outside of lowes or HD.
Lastly, I am unsure how the exterior outlet would look as I want to be able to run an RV or HD extension cord to an outlet at the track. I watched a video of a guy who ran an exterior outlet on the outside of the trailer, and an interior outlet on the inside, then made an extension cord with two male ends. That doesn’t seem right, does it?
Any thoughts, things I should consider before I head down this path?
