adding 2nd tank to air compressor add cfm?
cammok5
south nj
i have a 60 gallon compressor, it is 3 hp, 11.5 cfm @40 psi 10.2 cfm @ 90 psi.
will adding a 15 gallon tank bump up the cfm or help keep the compressor from kicking on so much while painting?
e-tek
Saskatoon, SK
We used to discuss this all the time (like PVC airlines!) but not for a while! You get longer use times but also longer fill times.
thebeekeeper1
Illinois
A bit of a variation I've been wondering about--can you run two so-so compressors (the usual $400 "60 gal./7 HP" in tandem, linked together with a valve to isolate one as desired, and gain enough to be worthwhile. That would be MUCH cheaper than buying one good compressor. Is that like dividing by zero?
Provincial
Near Salem, OR
If you use a compressor very much, or need the higher volume very much, it is better to have one compressor with higher output.
The extra compressor will take up room and require extra wiring (and circuit capacity at your panel) in addition to the plumbing. If you don't do your own wiring, you need to consider the cost of the electrical changes. If you now have a 30-amp circuit, you can handle most 5 hp compressors.
Upgrading to a two-stage compressor of the same horsepower will give you in improvement in output. Stepping up to a 5 hp two-stage compressor will improve performance significantly.
larry_g
oregon
Air delivery is determined by the motor HP and the pump size. If you have to stop and wait for the compressor to catch up now then the extra tank will not fix it. Like Provincial said we have had this discussion a few times and I used to post Why. If you search on my name and pump or compressor you will find a few threads around this subject.
lg
no neat sig line
The problem with two compressors is managing the on/off times. You need to have one control, and then maybe have that turn the power on the two compressors via separate relays. Otherwise one will come on before the other, up goes the pressure, and the second will never come on...
Then there is the power constraints already mentioned.
larry_g
oregon
To me this is the ideal situation. If one compressor will handle the load, no need to run the second. With each having their own pressure switch have one, for single stage systems, with a 100psi cut in and the second in the low 90's then the second will only cut-in if your nearing load critical minimum pressure say 90psi.
lg
no neat sig line
TwoInch
NW INDIANA
lg
no neat sig line
thats excactly what i was thinking. if only using normal amount of air, the second would never cut on. only when using high volume would the second kick on. sounds like a potential "winner" if ya ask me.
OccupantRJ
Eastern North Carolina
This is the way I have done and used my compressors for years. Works very well.
PowerDubs
I have 2 identical compressors sitting next to each other and just hooked together with a T fitting.
Fire them both up, let em fill. If I am just wacking a lug nut, etc.. then the 1 pump will kick on. If I am using more air, then the other one will kick on soon afterward. Works great.
finn
The UP, God's country
Larger storage capacity will help, but not as much as a bigger compressor.
Multiple compressors are better than single compressors (doing more work) but messier to deal with than a single, larger compressor.
DekeT
USA
lg
no neat sig line
I like this idea a lot and I understand the cut-in and cutoff principle. Some hardware is needed to prevent the 90 psi tank from getting air from the first while still being able to measure air pressure in the main line to start and its own tank for cutoff. What does that look like? Anyone with a general parts list for plumbing the controls?
QwikKotaTx
Seabrook, TX
Lol, I knew the other forum you peruse by the last sentence even before I saw your username.
When my Crapsman dies I want to use the 25 gal tank as a receiver for one of those little Makita oiled compressors but don't want the damn thing to run all day.
larry_g
oregon
You do not need the " hardware is needed to prevent the 90 psi tank". Both tanks are on line, like your original post, all the time. The first compressor to kick on will fill both tanks or if the load is to much the system air (both tanks) pressure will drop until the second compressor switch reaches cut-in. You can put a ball valve at the exit of each compressor tank if you want so that you only have one compressor online if your just doing lite work.
lg
no neat sig line
TwoInch
NW INDIANA
not needed. you essentially are making one large tank out of the two tanks. if you think of it that way, one tank with two pumps feeding it, one set to cut in at 100psi, and the other set to cut in at 90psi, it should make more sense. you want them both measuring the same tank pressure. isolating them would defeat the whole idea.
thebeekeeper1
Illinois
Hello, my ARFCOM brother! :thumbup:
cagullett1
North Texas
I keep reading other places about using a check valve on the compressors before the T, is this really necessary?
larry_g
oregon
Not according to me and a few of the others who have posted above. If you want to believe the ones who propose using a check valve then go ahead. CAn you provide a link to the other places who are proposing a check valve? Maybe I can read their whole post and understand their thinking behind the proposal. There is a check valve between the receiver and the pump head, but I would not have one anywhere down stream of that.
lg
no neat sig line
