Adding 60 Amp Circuit To This....
Norcal
Only GE has half width double pole breakers like that which is why he thought they were twins.
If they are indeed GE and that panel is not GE then those dont even belong in there and im surprised they got them to fit as the stabs are different
Challenger & Crouse-Hinds twins allowed them to be used for 240V, now because they are obsolete anything other then GE requires a quad for 240V
Jason280
But I'm taken by the idea that a TIG machine needs 60A.
Depends on the machine...the newer inverter style TIG machines require much less amperage than older transformer styles. I have a Lincoln Square Wave 175 TIG that the input current is rated at 65a for AC TIG, and that's at only 150 amps output. Step up to the big 300a machines, and they require 100a service. Flip side, and inverter based 200a TIG will likely only draw around 30-35 amps.
