Homemachineshop
Hello everyone, this is my first time posting on this wonderful forum, and I have a question about heating the 30x3 garage I am building.
I'm installing a Navien mod/con combi boiler in the shop, the smallest one they make, which can turn itself down to 12'000 btu's, which is still quite a bit for my shop. Max heat loss is estimated at 25'000, so the boiler may be short cycling quite a bit in the spring and fall, when the heat demand may only be 6-8000.
I've got about 950 feet of 1/2 pex running through a 6" slab
After researching online I came across guys adding a small hot water tank to the system to act as a buffer tank, so the boiler will get longer cycle times.
Any heating experts out there think this is needed? Or will the slab thickness and large thermal mass help me out?
