What I have tried to do is simplify my life, with a simple solution.
But now jonjon1 has me thinking about his current sensing relay setup in post # 15. I may end up simplifying my life with a complicated solution.
jp
LOL, I always say, "if there is a complicated way to get from a to b I will find it", lol...
That is not that bad, its actually pretty simeple, if I drew it out for you, current sensing relay is a switch, transformer is a power source for the contactor, and the contactor is just that... 3 devices, its simple, lol...
NOW, if you seen how I made my lift stop crushing the door into the office, that is genius, lol...
So for some reason, one of the lifts is near the door going into the office, the office door is supposed to have an auto closer but the guys jamb it open so they can hear the phone or door buzzer, tv, talk to someone sitting in the office, or what ever... BUT the problem is they lower a truck and rip the door apart, this only happened 3 times before I decided to change it LOL!!!!!!!
SO what I did was...
I put a switch (like a car door switch in the jamb) on the door going to a RIB, when the door is closed it activates the relay which opens a solenoid valve installed in the release lever plumbing of the lift, SO when the door is open the solenoid wont let the lift go down, when the door is open..
OK, so that works great, NOW to take it a bit further, I put an electric lock on the door, and a strip of contact on the lift at the point where the door will kit the car on the lift if it is opened, a so the metal strip and a little finger drags up and down the lift, when it gets past the point of the door it unlocks the door...
NOW say what you will, BUT WE HAVE NOT changed another door since I did it!!!!!!!! That is results...
One more for you, on a servie vehicle my guys kept leaving the tail gate open and dumping stuff on the street and in customers driveways, everything from full furnaces to boxes full of fittings...
So I put a light on the dash with another door pin on the tail gate...
DIDNT work, so I put a strobe light, still once and a while didnt work, and the strobes burnt out, so I put a car horn in the cab, if you turn the key on and that tailgate is open, it blows you out of the cab, lol... NO more dented up furnaces or a/c units that fell off the back of the truck....
