Jaguar Fan
Seeking a little wiring advice. How would accomplish this? Or rather, how would you suggest I accomplish this?
I want to add a 240v 20 amp outlet in my garage. I'll use it for a portable charging cable for my plug-in hybrid. The charger plugs in to a standard household electric outlet (120v), and comes with a physical adaptor so it can plug into a 240v outlet. The writing on the side of this charger says either way it draws 16 amps.
I have an existing 240v 40 amp breaker in the box - it is wired to a single location somewhere else in the house; it is unused. I was thinking of just disconnecting the existing wires from the existing breaker and add an outlet right next to the sub panel. But perhaps that is a dumb idea.
Here are pictures to help visualize this:
1) I have 600 amp service to the house:
2) There are three sub-panels in the house, two of which are inside the garage while the third is in a closet inside the house. Each of the sub-panels has a 200 amp breaker for that sub-panel:
3) Here's a sub-panel in my garage:
Here's the panel with the door open:
And with the cover off:
And specifically:
4) The other end of the existing wiring from that breaker I wish to repurpose - that circuit is not used:
My thinking is to run new wire up through the top of this sub-panel, and then someplace above it, cut a small hole in the sheetrock for the new wire to come out. At that point, I'd use surface mounted (that is, not behind the sheetrock) 4 square box on the wall above panel, EMT pipe & connectors to put a surface mount box for a 240v outlet. I hope my description is clear.
Is this a dumb approach?
Instead of repurposing the existing 40 amp/240v breaker, should I just add a new 20 amp/240v breaker? Physically it appears there is space on the left bank to do so.
Here's one issue - the inside of the sub panel at the top is pretty darn crowded already. Ideally I'd go up this side - I guess I can fish wire up though one of those knock-outs
Any thoughts/advice?
Or should I just bite the bullet and hire a licensed electrician?
Many thanks for any comments.
And specifically:
