Adding a garage onto this house?
jserr68594
I am looking to add an additional garage onto the side of this house. I would like to attach it, but I cannot come up with any good ideas that will not destroy the symmetry/look of the house, so I may have to do unattached. Does anyone have input? Thanks in advance!
FordTruckWench
California
Perpendicular and in front of the house with a small gap between the structure corners? In other words, with the doors at a right angle to the house. You already have the approach driveway to get into such a garage.
NWOhioChevyGuy
Buckeye Hill (Morenci, MI)
Check on set backs from the property line. Most places you need a minimum of X' unless you get a variance from the zoning board. I agree with the thought on the placement being perpendicular to the house/drive.
jives
Central NY
Building where you marked, or perpendicular like FordTruckWrench said, would seem to limit access to the back yard. Perhaps perpendicular, but move toward the front of the property.
The photos of the front of the house show a body of water in the back. How close is that? The water does not appear on the aerial photos (or my eyesight is poor). When you said a hill in the back, are you referring to a slope dropping away from the house? That can be easily (not cheaply) dealt with.
BTW, is this a true garage -- for cars -- and not simply a workshop?
u2slow
BC
IMHO, the perfect mirror-symmetry is gone anyway with a detached garage positioned so close. With setbacks, you're losing the walkway's-width of square footage too. I would do attached and copy the roofline of the taller center-section of the house.
Also double-check your bylaws. I could have a bigger garage if it was attached. Detached was capped at 750sqft.
Joe Reed
Cordova TN
If the suggestion of perpendicular to the house doesn't work for you, I'd move the new garage addition back several feet from where you have it drawn. That would be less intrusive to the symmetry of the existing house.
billconner
Thousand Islands NYS
Build detached in rear corner of lot as close to lot lines as zoning allows, and extend driveway along side. Also makes it easier to change style if desired.
First step should be a good site plan with zoning required set backs drawn in. Then, if in an HOA, add those restrictions.
FordTruckWench
California
The OP can't build in back: There's a lake back there. You can see it in the second and third pictures.
Stuart in MN
Minneapolis
You'll likely have a more difficult time gaining approval to build right up to your property line than dealing with the slope at the rear of the property.
This is most likely the case - it doesn't look like there's enough room to add on a garage bay before you run into setback requirements, but of course that depends on local regulations.
LOW1
ontario
The center part of your home with the shed roof may make it difficult aesthetically. The services of an architect would help.
What about tearing off the existing garage and replacing it with a side entry 4 car garage?
CTyankee
CT
I'm not familiar with brick homes do I don't know how much work it would entail. I'd try to add a single 2 car deep garage to the existing garage. You'd have to alter the side of the existing, but it would also allow you to have the 2 spaces open to each other if desired. Symmetry wise I think you're SOOL.
andyvh1959
Green Bay WI
If you go attached, depending on your location, it means a full below frost depth foundation is required. If you go detached you can likely do a slab. Also, like said before a detached garage may be built larger depending on set back requirements.
When I built the 7-car garage at my previous house, the city would limit me to 900 sq ft for a detached garage. I asked, "would an attached covered walkway from the garage to the house define it as "attached"?" They agreed. I designed a covered walkway from the back door of the house to the side door of the garage, with a connection to the garage wall that allowed for vertical deflection. City approved it and I built a 1350 sq ft "attached" garage. Still wish I was in that house.
