Well after a lot of planning, got my shop wired up by a local company a while back. Originally I was only planning on having a small welder, because I can use the big ones at work anytime. I have traded and acquired a Lincoln power mig 255 all of a sudden. Now I need it fixed up to use. My local guy is shutdown right now due to surgery so I was hoping to go ahead get this finished.
I would like to use 14r 50 plugs because that’s what is the standard at Work has been swapped to. Going that route nothing will hook to the neutral, any code issues there? It will be a 20 foot run from my panel....I’m seeing quite a few different wire sizes that is recommended. What would be the best for me to use? Also will be needing a 60 foot extension cord. This will get me outside where I will be setting up some work. What is the recommended cable type for this?
Would I be better off pulling a 4 wire as opposed to a 3 due to the plugs I’m using. Would that still work will my welder even though it doesn’t need the neutral?
Will appreciate any help, thanks. Attached is the welder specs. I’m capable of doing all the work just not sure of sizing requirements.
