gasgas17
So like the title says, I'm adding a winter storage bay on the back of my home based shop we use for my renovation business. Business has been pretty good the last few years so I'm trying to get some very over due home renovations done to my own house. Bad case of the cobblers kids have no shoes or the mechanics car. I have 14 feet behind my garage that is nothing more than a junk collector and I need some winter storage for the boxster and the street bike. We have a mandatory set back of 4 feet on the back line so the most I can build is 10 feet. on the back of my 22 foot deep shop. The back right corner also has an easement for the main sewer line that comes up the back yards on my street. So I need to cut the width short on the addition to 22 feet. The existing garage is 24 feet wide. So the new slab size will be 10' x 22' and I plan to build a sloped ceiling to give it a more open feel. I was really tempted to sneak it in 12 feet wide, but I didn't want to chance ******* off the neighbors by getting too close to the line. I'm already building 100 square feet over the maximum allowable size of 650 square feet for a garage in my area. Although I have enough lot space that I could build a second 650 foot garage. Makes sense eh?
First up was to get rid of a tree that would be in the way of the new garage door. This maple was hit by lightning a few years ago and the back side of the trunk was missing and allowing the trunk to rot out, so it had to go anyways. Measuring the height of the tree with my tape from a hundred feet back and scaling it out, I figured I had about an extra 4 or 5 feet from the house when it falls. So I cut it off 3 feet from the ground for a little safety margin. Landed 8 feet from the house.
As you can see the back of the house is also due for a refit. I'm working my way around a side at a time with all new windows, doors and siding as the wallet allows. Getting it graveled in after excavation of the stumps and scratching the rough grade for the slab.
Ready for rebar and wire mesh. No engineered slab on the old existing garage but it did have a 4 inch curb. Just going with a flat slab on the addition, but with a thickened footing around the edge as per the standard engineered slab method for our area.
Should have added some calcium as the temperature was getting a bit low. Around a high of 8 degrees C the day we poured. It was just getting hard enough for the power trowel at midnight. Kind of gave up and hand troweled it off and went to bed. Although it did take a pretty good polish with the power trowel first thing in the morning. Can't believe it took that long to cure. Lucked out on the finish anyways.
The next day we had it mostly framed up.
