I own a small carbon repair and custom paint shop. I currently run a 60 gallon compressor that does great for what I currently need. I want to add a blast cabinet to my shop and need to up my CFM's from about 13 to 20. I have access to another compressor that is currently damaged that is the same size as my working compressor. My thought was to fix the motor on this broken one and have two compressors on my system. My question is this. Do I need to run them next to each other, with one feeding air into the other to get the increased CFM, or can I just plum the new one into my system in a separate room (not as noisy then) and still get the same benefits? The blast cabinet would be used for removing paint from bicycle frames, so probably not run very long. Putting the two compressors together should up my CFM to 26 if I do it correctly, so that should be enough with room to spare for the blast cabinet. I imagine no matter what I will need some check valves to keep air from running backwards in the system but in my head I don't think I need to run them one feeding into the other right next to each other? Thank you.
