Hi,
I am in process of adding a 100 amp sub panel to my attached garage. I have the wires pulled to my 100 amp lug panel from my 200 amp service panel but not connected at the 200amp service. I am clear on connections at the 100 amp sub for the most part.
I was going to get electrician to connect my pulled wires to panels but as i progressed and read more and more decided to tackle cautiosly myself. I still may get my electricain to come over before using to look at but want to do majority myself and get good understanding of what needs to be done if i have someone else complete
1)First question is the "bonding screw" in my 100 amp sub/lug panel. i assume that is needed as my 200 amp main panel has neutral/ground attached together(bonded?).
2)In my 200 amp main (siemens) there are still 8 breaker spaces but all but 4 neutrals are filled. Is there a "add on" neatral bar i can purchase?It looks like panel has provisons for this or do i need one longer strip? How does this connect? What is its real name? Reason i need more is i have 1 circuit for garage (2/2/2/4) 100 amp, and 3 circuits for lights and outlets in basement i ran 2 years ago and never hooked up to panel. Was waiting to get electrician for that too. so i need 4 neutrals and 4 grounds on the strip
3)regarding neutral connection, existing has neutrals and grounds to same strip. The neutral and ground each occupy a space. I would guess thats the right way, but can they be doubled up? Neutral and ground in same space?
4)also for the #2 neutral for the 100 amp sub, is there some kind of adapter to go from the small size terminals to the #2 size? There is a existing 100 amp sub for generator switching panel that has something similar.It looks like it takes 2 small spaces on terminal strip and adapts to one for the larger wire size. Whats that called?
5) whats the "paste" called that should be used on the aluminum 2/2/2/4 connections? I see the original electricain used this on the incoming service. Does it get used on all connections involving the aluminum wire?
Thanks!
Ryan
Thanks!
Ryan
