Adding Dead Bolt to Steel Door
AviationMan
Is it possible to add a dead bolt to this style of insulated door? I want to use one of these nest locks, I also have to have a keyed Knox Box for fire.
wayne55
Just have to use a holesaw capable of drilling metal. I added several deadbolts to my house that has metal
doors, although they are not what you would call industrial.
CraigStu
Blacksburg, Va
Can you find a model # anywhere on the door. My concern is that a lot of doors only have interior wood or whatever in certain areas. At the conventional latch and deadbolt locations the inside may be filled for 4-5 inches in from the edge. The rest of the door perimeter may only be filled in 2 inches from the edge.
steaks&anvils
Colorado
The door manufacturer information should be on a tag on the door edge, hinge side, near the top. It will list manufacturer, fire rating etc.
rjn2649
Il, A little west of Chicago
It's probably hollow. Get an Ames door lock support. They are made for hollow doors. Just keep in mind you are probably adding THE LOOK of security, more than any real security. Yeah it might slow someone down, but cheap hollow steel doors bend easy enough.....
D-train
The two steel exterior doors that I bored into DID NOT have wood in the area where a deadbolt would go. (cost effective design) I had to hunt for the lock support mentioned above.
Pate
New York
If the door doesn’t have a knockout for the latch prep on the edge of the door then you have 2 options. You will need to use a drive-in latch (round face) or a dull metal chisel to form the prep. We have a tool to make the prep, but it’s not cost effective to buy unless you use it multiple times. The Ames door support or a block of wood is needed to keep the door from compressing when tightening down on the screws. The main issue we run into on steel doors is the lock loosens up and the drive-in latch lets the whole thing slide out and smash into the frame. If you do go with a standard face I also highly recommend you rivet the latch in instead of using the 2 screws in the face.
The Cobbler
^^^ Lots of good points, I concur with all of them .
The dull chisel works well to form the metal style to recess the latch . Take your time, don't be too aggressive & you can achieve quite good results!
