Adding extra Leverage to a Combo Wrench
Cervidae
What do you guys all use to add extra leverage to combo wrenches? Thanks
Stephenw
Utah
Like this...
Kracin
Omaha, NE
I'm a little weary of linking my fd+ like that, how well do they hold up?
we used to "double wrench" all of the bolts when assembling machines at the pipe foundry, but we were using 2 1/4 wrenches and 1 7/8. two people hanging off of the second wrench in order to get it tight enough and "torqued down". definitely made for a fun time when removing them next year during next shutdown.
but i've used this old trick many a times to get a little extra leverage in tight places, or where a wrench can be hard to push on by hand. never had a problem, on just plain old craftsman wrenches.
also used wrenches many a times to turn other things like allthread with a t handle that have been overtightened and had the shaft bent so it was hard going all the way out. never an issue.
I've been doing the double wrenching periodically to my Craftsman RP wrenches for decades and to my dad's old Williams and Protos before that. never had one fail personally...
Dberglind
I have been using the "double wrench" technique, for years as well, and it has never caused any problems with any of my wrenches.
jmm
NC
If for some reason I can't do the trick as posted above and a pipe won't work either, I've run a thick allen wrench or something else solid through the closed end (ideally, open end works too, just watch for busted knuckles). In tight spaces, I can lean on a wrench much easier that way.
devilsnight
"double wrenching" will put little nicks in the open end of your wrenches. doesn't cause any problems but will happen. Nobody ever seems to admit to it but, I do, in a pinch. Difficult to reach turbo mounting nuts, I use a 3lb hammer to pound the wrench around the rest of the way. again, doesn't affect a quality wrench but..... works
Fedwrench
Valley of the sun
When I went to school at the GM training Center in Burbank, there were a couple of Snap on combination wrenches that had the open end jaw broken off form doing that in the engine classroom.
Don't do it. use a longer zero offset box end wrench, or a socket with a breaker bar.:wtf:
Chuck122
Québec, Canada
Every time I'm about to double wrench, it looks to me a thought the wrench is not meant to be stressed that way, then I feel like a **** and find another way
jakemac
New England
Rubber mallet or a deadblow.
If it don't fit, get a bigger hammer.
If it breaks, blame the next guy.
Olafur
Iceland
I guess the real trick to double wrenching is to know when enough is enough! ;)
I sometimes resort to thin wall square tubing if more leverage is needed. For example 20x40mm for 22-28 mm wrenches. Gives better control than a pipe and is relatively light and requires less space than a pipe.
greasemonkey44
memphis
i use a longer wrench, double wrench, pipe, or a deadblow
usually the dead blow does the trick or an impact
All
Square tubing. Insert open end of wrench on the diagonal.
The diagonal of a square is significantly longer than the diameter of a circle for a pipe roughly the same outside diameter as a comparative square tube's width from flat to flat.
Try it. You'll like it.
sberry
Brethren, Michigan
A tubing on occasion, a hammer if needed. With this version the bolts are adjustable and the heads could be modified but its a last resort kind of thing, low duty cycle.
Kracin
Omaha, NE
imho it's less about "using it the wrong way" and more about "using it in a situation that calls for it", like when you have a wrench somewhere in a deep spot, and absolutely need some more torque on it, and can't get a socket on it, but can't get the leverage you need. it's far less taxing to use this method than to put a hammer to the end of it. in my opinion.
richfinn
Leeds, Yorkshire, England
I like to use my serpentine belt tools if I need more leverage (size permitting), but I have linked spanners together as well for years and years and never damaged one
sberry
Brethren, Michigan
I actually like yours better from design. I put a 1 1/4 pipe on a long handle double box Cman,,, 36 inch added leverage, came with a snap, must have been in hundreds of ft pounds.
rick carpenter
Huntsville, East Texas
Who makes the beefiest box end wrench? Some mfr not worried about slimness or tight access. If cheap enough, you could just cut off the open end and use whatever pipe length you need. Or use ironworkers' spud wrenches.
4x4gearhead
New Hampshire
I usually double my wrenches up like mentioned here. I have found however that it isnt always effective with my modern snap on combinations as they are too thin. I have a piece of 1 in wide by 1/8" strap with a couple prongs welded on it perpendicularly similar to Sberry's and Lilredex. I have seen an actual manufactured version of these tools before and have considered buying one, Ill try to find the link.
4x4gearhead
New Hampshire
Here is a picture of a Lee Valley made extender, didnt have time to look around at prices, but this looks like something Id like to have.
TangoFoxTrot
I have one of those and I've used it quite a bit. It's held up really well.
It's a great solution for when you need large wrenches and something like a cheater bar is just too small to slip over a wrench end.
4x4gearhead
New Hampshire
Nice! thanks for the input, Im currently looking into getting one, It would be great for reaching hydraulic hoses i'd bet.
