YoshiMoshi3
- Joined
- Nov 2, 2022
- Messages
- 509
I drilled a hole into an outer tie rod. Tapped it for a zerk fitting, installed the fitting and added grease. I've seen a couple of people on YouTube do this. I was surprise how much it took. I was able to install it in the car. The new ball joint was nice and tight. But when torquing it down to spec the boot blew passed the spring clamp and grease came out from the base of the boot. I probably added to much grease. I tried to remove the part, take off the clamp and get the boot and clamp back in place. Even with the clamp back in it's proper place, grease still came out of the boot, I probably overstretch the clamp. The ball joint now spun very easily, making it very difficult to reassemble because the ball joint and nut spun together.
This got me thinking about a few things:
- When adding zerk to ball joints via a zerk fitting, you can over-grease very easily and there are no provision for grease to be expelled from the joint. Where does the grease go in a sealed ball joint? Seems like I should add grease every oil change, because it could result in over-greasing. So I should just check to see if the boot is nice and firm. If it's firm do not add grease. It seems like once I have added grease to the joint, I won't need to add grease ever again, or only once every several years? This is opposed to greaseable ball joints from the factory, that you should grease every oil change.
- Is there a specialty tool to remove or help install the spring clamps for ball joint boots, without overstretching? These clamps.
