csp
I have an existing building that had 4/0, 4/0, 2/0 wire running from the power pole to the building in a trench when I bought the place in 2000. It had never been electrified, however. The wire is way overkill as the distance is only about 60'.
I'm finally to the point of powering this building and would like to use the existing URD and just add a ground wire. Can I do this? I was told once that the ground had to be twisted with the other three wires to be up to code. I"d really like to avoid replacing the existing URD as it's up to the task.
It's easy digging to open the trench again as I've done it once already. I can set my trencher a few inches above the cable and just pull the cable upwards through the remaining depth.
#2 related question: My power pole contains the meter and a feed through panel that powers my house underground via the feed through lugs. I will be powering the building from a breaker in the feed through panel. To avoid wrestling the 4/0 conductors into a breaker I had planned on cutting them short underground a few feet from the panel and reducing to 1/0 with an underground splice. Which type of splice do people recommed, the ones in a plastic, gel filled enclosure or the ones with the glue heat shrink? Or is it six of one, half-dozen of the other?
