Adding lean-to to a floating slab - proper post footings
Bolson32
Lake Elmo, MN
Hi All,
I'm looking to add a small lean-to to my thickened edge floating slab. I think the city required it to be 18" edges, of which about 12" is below grade. What is the proper footing detail for a post framed lean-to? I probably don't want to do 36" but I also don't want it to rip off during a windstorm.
Anyone done this recently?
dougf
Missouri
I'm glad you posted this. I have a 20x30 thickened edge floating slab and have been researching the exact same thing. The consensus is to do a stand alone lean-to structure up against your building to prevent things issues from frost heave. However, my assumption is that similar footings that are used in the structure for the lean-to would be fine as the ground would freeze and everything would heave in unison, but I could be very wrong. Looking forward to the experts chiming in.
bb29510
i did this on my back porch, I cored drill through the slab witha 12 inch core. ( sorry, I own one) then I hand auger four foot down and filled with rebar and concrete, now i took it farther than what you need. I had a eight foot , 10 inch pvc with I carred the rebar and concrete to eight foot, and that my roof cover post
Firebrick43
West central Indiana
The footer needs to be deeper than the frost line. What is that number where you live?
Did you insulate under you monolithic slab?
If it is and provide you have a footer that is proper depth then I wouldn’t worry about it
You can use treated wood poles on a cookie or a permacolumn on a cookie as well(preferably imho)
Bolson32
Lake Elmo, MN
That's kind of what I'm thinking. I don't necessarily want to prohibit the posts from heaving and I don't really want it as a separate structure either. I guess I could do that in theory, might be easier than cutting into the siding and flashing a new attached roof. But then I'd have another 3 posts in the way.
The footer needs to be deeper than the fronts line. What is that number where you live?
If it iss and you provide a footer that is proper depth then I wouldn’t worry about it
My slab is not insulated and the thickened edge is about 18", code here. It's a floating slab though, not to frost depth. 42"
bb29510
i have seen up north, in unlivable bldg, you can pour a mat, usually heavy rebar, so when the slab heaves, the whole bldg moves. but its not legal for residents
dougf
Missouri
Question for the experts. We know the slab is going to move, will a lean-to with the exact same footings for the posts move with the building as the frost comes without issue?
Firebrick43
They will not move together properly.
On top of it if it’s not shallow frost protected, many jurisdictions only allow a certain size building to be built this way as the thickened slab edge can take the forces. As you get bigger the ability for the edge to do its job is exceeded. It functions no different than a beam. Many places actually call them and similar “grade beams”
billconner
Thousand Islands NYS
I don't know size of either existing building or proposed lean, nor use of either, but I'm guessing neither on frost heaving presents very significant life safety issues. I don't think it matters a lot how the posts are set, as long as they'll hold the weight. I'd simply design the lean rafters to rest and "slide" on the header atop the posts, and figure out a way to hold the lean roof on the header against wind without restraining it. There might be slight non-straightnees/lean in the future, probably most noticed in the lean eave. Probably wouldn't bother me most settings. YMMV
Bolson32
Lake Elmo, MN
Good thing I'm not living in it. This would probably be the best solution. Essentially tie the two slabs together. Lots of concrete though.
This is my thought, it's going to shift a bit? Sure. Is it going to matter for the tractor attachments I'm putting under it? Nope. I'm not going to sheetrock it.
NUTTSGT
Northern Central Ohio
First and foremost, check out what is required locally, both to code and frost depth requirements.
Once you have that information, start your planning with that information in hand.
Bolson32
Lake Elmo, MN
I feel like you're missing the point. Frost depth is not required for outbuildings as was mentioned in my original post. I just built the garage 2 years ago.
I've since been through the code and there's no mention of depth requirements for porch posts on outbuildings on floating slabs.
NUTTSGT
You may not need to follow code for frost depths but if you're using posts to frame this, I'd pay attention to what the code is, at least as a reference.
I surely wouldn't want to put an addition on using posts only to have them heave and cause damage later on, requiring more money to remedy the situation. You can proceed however you want and spend your dollars.
Bolson32
Lake Elmo, MN
I've done a bit more googling rephrasing as porch attached to floating slab and found some more results. Seems like consensus is to match and attach the foundations or keep them separate. Which does make sense.
billconner
Bolson - I'm not sure if you're planning a slab under lean or just gravel, but if a slab, I'd do same as enclosed. If gravel (which would be my choice) just concrete as deep as your thickened edge.
One or the other or both may move a little. Frame accordingly. You could look at I'm drainage also, keeping water from ponding near the building.
In my area, the floating slab is limited to 600 sf and to accessory buildings - plain IRC. It sounds like you may be beyond that size but still permitted there.
Bolson32
Lake Elmo, MN
I already have gravel there, was hoping to just sink a few biscuits in the ground and put posts on them and run a metal roof to the main building. Garage is 16x32 and not conditioned.
I have a lot of tractor equipment, pallet forks, blades, buckets etc that really don't need to be inside, I'd just prefer they're not in a snow bank all winter.
If it shifts...meh, I don't really care as long as nothing breaks. It's not like I need to keep sheetrock from cracking.
ConCretin
Central Maine
I'm kind of late to the party but I'd just pour a slab similar to the existing one and call it a day. What you want to avoid is differential movement between the existing and new structures. If the existing foundation 'floats' on the frost, the addition should too. You don't want a structure sitting on frost protected piers connected to a floating slab.
bb29510
need to invent some type of ball joint on the existing building so it can move, without ripping your house apart
bb29510
off topic kinda, when ever we build long building we will have two beams, ususally concrete beams ,sitting on top of each other, not connected with a teflon sheet in between, so the building can move
