audi noroad
So I found out on Friday that at work one of the fluorescent light fixtures broke and they are going to replace all 4. The remaining 3 that are still working are going to the dumpster. As you probably already figured out I asked about taking them off there hands, and it sounds like there ok with it.
So now I'm trying to figure out if it's going to work ok in my garage. I still need to figure out what kind of wattage I'll be dumping out and if the 20 amp breaker is going to be enough. The area above the garage door doesn't have any lighting at all and I'd like to add something there that I'll turn on when the door is down. The second issue is I think the bulbs are T5s in the fixtures at work, and of course we have something bigger I think T8s I'll have to check again it's whatever you find the most of at Home Depot.
So here's my thought if it's ok to mix them put the T5s where the current fixtures are and put the third one by the door into the house since there is more space over there. Then put the current fixtures above where the garage door is.
Here is a photo that shows the current setup. The lighting in my opinion is good as long as your standing under it or just getting something out of the garage. I have to pull out a shop light every time I want to even think about working on the car. Even if it's something on the door.
I guess I should mention the reason I'm being cheap about it is that this is my mother's house and I'll be moving out at some point so I don't want to invest a bunch into a garage I won't be using for more then 2-3 years. If it were my own garage I'd probably either take the 3 from work and buy 2 more or just buy all new ones.
