rvr6000
Buddy needs to add an outlet for a stick welder but the inside of the garage is finished and has a recessed panel. (I thought ahead when I did mine
) I think the plan is to put the plug on the west wall....panel is on the NE corner so it'll be about 32 foot run or so.....too much to want to tear all the walls apart.
I'm thinking just run PVC conduit along the wall from the panel to the outlet. As for the conduit to the panel - we can make an access into the wall cavity to get into the panel easy enough. Would you just use a conduit body to make that turn into the wall then flexible into the panel or keep it rigid?
Hope this makes sense.
