shop_hermit
I would appreciate some advise on the size of power cable I should run to a shop. The distance from the main house panel to the shop (cable length) will be about 160 ft. I want to run aluminum feed cable for a new 100 amp panel in the shop. The cable will be buried and in 2 inch pvc conduit. I expect that with a small heatpump, running table saws, a fan and a dust collector vacuum, other tools, welder and lighting, I may pull on a regular basis up to 65 amps.
I was thinking of using 1/0-1/0-1/0-2 AL service feed for the 160 ft.
Is this overkill or not good enough?
Thanks.
Thanks.
