Adding security lights to a stucco exterior
930dreamer
Amarillo,TX and Stinnett,TX
A co-worker wants to add two exterior security lights to the stucco exterior of his house. These lights will be mounted high on the walls. I was thinking liquidtight flexible conduit that taps into an exterior receptacle/new gang box? I'm not sure if there's any place off the flat roof to get power from. Are there any conduit that would work better? Thanks.
Mustang51js
Haskell nj
Really depends on where you are getting power from,the flex is just to protect the wire from the elements, if you can come right out the building and put the lights right there then you wouldn't need flex or pipe. Your prob going to need long screws to mount the box though
