adding toilet with no existing plumbing
deerhunter88
Im wanting to add a half bath in my shop and have no existing plumbing drains in the concrete. is it best to go with a back flush toilet ($400) from home depot or build a stand for a cheaper toilet? Any one tackle this task before?
readhead
Durango, Co.
Need a lot more info. How far do you need to go to get to existing sewer and water? Is it downhill or uphill? Can it freeze?
D
deerhunter88
i will be coming straight through the back wall with water. Sewer from my house is alos ran 5' from the wall i was planning on coming through with the drain line.
K'ledgeBldr
Johns Creek, GA
Well, that's definitely not what was construed from the Title or your original post. So, I'll definitely reiterate my original post- No Plumbing would definitely make an incinerator toilet a very easy compromise- and no permitting would be required. Which leads me to a more direct question- if you're going to permit this, why not ask the AHJ what they want you to do?
D
deerhunter88
No permitting is required. Maybe i should have said no existing plumbing in slab. I plan to pipe through the wall and tap into current line going to my septic tank. I dont not want to break into the cement slab.
6768rogues
Western NY
My bathroom has the door swing and vanity at the barn floor level, with the toilet and shower one step up. The stepped up area is about two thirds of the room. The plumbing for the toilet and shower are below the step up with no concrete being disturbed. It goes out the back of the bathroom, turns 90 degrees and exits the building above grade. I painted the pipe outside to match the building.
gordyy
North Dakota
than a wall hanging toilet is the cat's behind for you. run a vent up inside the wall cavity for the stool and a sink, of course an adequate wall support and hanger for a wall stool.
Wall stools are great till you have 350 lb guys sitting on them make sure your walls studs are good double them up if you can there is a lot of torque on a wall toilet, and do yourself a favor hang it at the wright height not to high but not to low as we get older the toilet that's low to the ground is a pain in the knee.
barks
If near an outside wall punch a hole in slab and run plumbing waste piping through it. The reverence for the sanctity of concrete slabs is hogwash.
landlord30
Pittsburgh, PA
I've seen them before with a kickstand like attachment on the front for extra "support".
tab2
Boston
The easiest labor but most expensive: You can get a wall carrier for a wall mount toilet (water closet) much like every commercial set up. You need a lot of wall depth and the floor mount models have over a 500 pound capacity.
Barnabas
Raleigh, NC
Mine was built in 1935 and has the sewer pipe coming in from outdoors just above the slab. The toilet is one step up from the rest of the restroom. A split-level bathroom. You get used to it.
