Additional comments on Swisstrax Ribtrax
jcmartinab
Florida
I installed a Swisstrax Ribtrax floor in my garage in early 2013, and would like to share a few insights regarding this product with the forum. First of all, I chose the tile instead of epoxy flooring due to problems my neighbors had with even the professionally installed epoxy flooring. Stained or damaged areas on the epoxy floors could not be easily repaired, but a damaged tile can be replaced in less than a minute. I ordered sample Swisstrax and competitor's tiles and compared them, and chose Swisstrax as it seemed considerably stronger and more well built than the other brands. As I have a couple of classic cars that sometimes leak various fluids, I finally ordered Ribtrax tiles as they are easy to remove and fluid spills would be easier to clean. Sarah, the Swisstrax salesperson, helped me lay out a cool design, and calculate quantities and the order came through perfectly. The installation was easier than I expected --installing the outside edges took about half the time due to cutting tiles to go around water heaters, air conditioners, steps, workbenches, etc. Once that was done, the rest of the inside tiles were very easy and almost fun to install as they went so quickly and you could see the garage floor transforming in front of you. The whole installation was only about half a day, which was not bad for one person installing over 800 square feet of flooring. Maintenance has been practically nothing -- I have vacuumed the floor a couple of times, used a leaf blower 4-5 times, and cleaned up a couple of spills and that is about the extent of it -- and the floor still looks like the day I installed it. I do keep cardboard under my cars for the leaking issues, however and I am sure that has saved me some work.
Bottom line is I think I made the right choice for my garage and if I had it all to do again, I would choose the same flooring.
Swisstrax
Indio, CA
Swisstrax thanks you for the business.
I am sure Sarah mentioned this but wanted to bring it to your attention as you mentioned a vehicle leaking and keeping card board down. I have a classic Jaguar in my garage and anyone that owns one knows they LEAK. What I do is remove a small section of the flooring where the leak occurs and lay down an oil leak pad so when I pull the car out no one knows I have a leaky vehicle! I change my oil leak pad out once every 4-6 months and you can pick these up at a NAPA or Auto Zone store.
Just food for thought. Let us know if there is anything else we can assist with and keep enjoying your floor!
Kind regards,
Jesse J. Stolp
Vice President of Operations
Swisstrax Corporation
82-579 Fleming Way, Unit A | Indio, CA 92201
Toll Free 866.748.7940|Direct 760.347.3330 ext. 102|Mobile 760.880.6605
Fax 760.347.3343
www.swisstrax.com
Follow Swisstrax
Swisstrax. GetFloored!
Shea
California
That's a slick (no pun intended) idea! I'll have to save that one for our next tile update.
