Advantage 4 post lift arrived
carryallman
i got the 4 post 11000# big model -CAN NOT BE WITHOUT IT NOW!!!! tony & the guys were great to work with ! there was 2 drips missing BUT THEY DID SEND THEM LATER ! did have to readjust cables -about 6 mos later BUT OVERALL -I WOULD BUY ANOTHER ONE !!! i use it for a big work bench most of the time ,real handy !
isb cornbinder
I will be buying a BENDPAC HD-9ST. The only reason for this choice is a good local dealer. They will take care of shipping and installation for me. I do not have any reason to think this might be a bad idea, so far. I am not brand loyal.
OldracerJones
Chico, Texas
Advantage customer service is great. I bought min about 5 years ago now and I developed a leak under the reservoir every time I used it. I didn't lean during the lift, only after pressure as off. Called Advantage and they discussed it with me, I pulled the reservoir and checked the torque on the pump bolts. Every thing was fine so I put it back together and it started leaking, even worse now. Called back and he thought it must be a small o-ring on the hose from the pump to the cylinder. They even sent me the o-ring at no charge. Changed it out and worked perfectly, no drips after a week. These guys are great.
PoorOwner
CA
Was it the O-ring that is inside the hose swivel or the one that goes against pump block behind a washer?
