Capt. Picard
- Joined
- Jun 1, 2025
- Messages
- 4
Was wondering if anyone who has an Advantage Lifts rolling air jack could provide some dimensions. I called Advantage lifts about this 4 times but nobody can seem to provide the data. I want to install an Advantage Lifts rolling air jack on a Bendpak HD9-XW. I like it a lot better than the Bendpak jacks because it has a much longer arm reach. Looking for the following specs:
1. Do the rolling wheels safely extend to 41-1/4 inches. This is the distance between the U channels where the jack wheels will ride on my lift. Advantage does not specify this.
2. What is the distance between the top of the U channel where the wheels ride and the bottom of the jack arms. Advantage does not specify this.
3. What is the minimum center pad to center pad distance. Advantage only specifies the maximum distance, not the minimum.
