metalmagpie
I've been monkeying with compressors this year, and am almost done putting one together. It is a 2 stage 4 cylinder Champion. I read somewhere that if I change the range on my pressure switch from e.g. 120-175 to 90-120 that I can actually get more cfm out of it. I don't really need the higher pressure for anything. My biggest demand applications are a blasting cabinet and a needle gun.
Trying to think the question through analytically breaks my brain. There has been enough BS written about air compressors that I don't really trust anyone's white paper. What is the actual truth - can I get more cfm out of my compressor if I run it at lower pressure? After all, if you look at air pump ratings they say things like 11 cfm @ 90psi or 8 cfm @ 120 psi - it does seem as though running it at higher pressure results in lower CFM.
metalmagpie
metalmagpie
