Advice for finishing outside drywall corner
trainbc9
Hello, new to this board. Looking for some advice. I've installed a metal corner bead on an outside corner. It is tight quarters because there is only about 1 1/2 inches before it meets an inside corner joint. The setup is odd since I removed an existing wall and couldn't just make it flush. The smallest outside drywall tool I have found (width) is 2 1/2". Is there an insider trick to be able to cleanly finish covering the corner bead? Appreciate any help.
**Additional detail--have been able to cover the corner bead sides but need to figure out how to cover the outside "bend".
mypov
you can usually get inside corner trowels ... being as there is such limited space between the inside corner and the outside corner, I would use the inside corner tool for the inside corner, and then simple use regular trowel for the outside portion - if that makes sense... but pictures would really help as I might not understand correctly?
-the inside corner tool has about a 1-2" flat portion that slides up either side of the inside corner and makes a clean corner...then use your 6" flat knife for the outside portion? - does that make sense?
NUTTSGT
Northern Central Ohio
A picture would help us figure out it out a little more.
I'm wondering if two 45° edges would alleviate the issue and make it easier to finish.
Mustang51js
Haskell nj
He's basically saying he's got a 2x4 laying flat on a wall and trying to finish it off. All I can say is take your time and do thin coats to build it up and sand in between coats
BD1
north side
Is this in a garage ? You could have a piece of stainless formed to match the dimensions. Looks good and protective.
The Cobbler
If I'm understanding you correctly and without pics we're sort of guessing , but , use your inside trowel to finish the inside corner & up to the "bead" on the outside corner. for the rest of your outside corner as other have said, use a regular trowel.
