I've decided to put up a large shed/garage type structure to store an extra car out of the elements and give me a little more storage for supplies etc. It's one that is available through Costco (only one big enough to store a car) and is basically a plastic type material with a metal frame. I'm comfortable that it will suit my needs (I decided not to add on another garage stall because of cost and other reasons.)
It will be placed next to my current garage under a very large tree. I'd rather not pour concrete because of cost and because I'd likely damage the tree roots, so per the manufacturer's recommendations, it can be assembled on a bed of pea gravel. This area has a gentle but noticable stope. Not knowing anything about construction, what's the best way to do this? Should I dig into the slope to bring the high part down to the level of the low part, then fill with gravel? How deep should the gravel be? Would the quickest way to do this be rent a tiller to pull up the dirt and haul it away? For better drainage should the gravel bed be elevated a bit and contained in a perimeter of treated wood? I'm sure the manufacturer will have a recommendation but this shed comes with some sort of a plastic or rubber floor - should some form of a plastic moisture barrier be installed?
Any other advice is welcome. Thanks as always
