Hello all,
My wife and I are going to be building a house and putting up an outbuilding on an ~80 acre piece of ground here in the next year or so. We are mostly done with the design phase of the house and should be getting the finalized plans from the architect shortly. The house is a traditional two story house with an attached 3 car garage, a walk out basement which will be be mostly unfinished for use as an exercise area and a wood shop, and I will have a detached metal outbuilding. I have not started anything regarding the outbuilding. I would like some feedback on a few of the details before anything moves from the paper phase to actual construction.
1. The attached garage will be a 32' wide x 28' deep three-car garage with 16x8' and 9x8' overhead doors. Ceiling will likely be at 12 feet. We will just use this to store vehicles, currently a standard-length 1/2 ton pickup and an Explorer. I picked this size as this is essentially the same size as a garage at a previous house that we liked, and four feet deeper than our present garage, which is too shallow but otherwise fine. My question with this is regarding lighting, so I will put this in the lighting forum. I just mentioned this here to say our daily drivers won't be in the outbuilding.
2. The basement will be divided into two rooms. There will be a semi-finished area on the walk-out side with a double entry door to a concrete pad and wall of windows. This will be drywalled and have a suspended ceiling, and we will use it as an exercise room. The other room will be 850 square feet and will contain the mechanicals and my wood shop. The house will be mostly propane except for an electric dryer and almost certainly would get a 320/400 amp 120/240 split phase service with two 200 amp panels. I have a couple of detail questions here as well but will also ask them in the electrical forum. I won't have any of my wood equipment in the outbuilding.
3. The main question I am asking here is some feedback on putting up the outbuilding. It will be used to store a tractor and a few implements for taking care of the property, and likely will also hold a flatbed and dump trailer as well as the zero turn mower and other lawn/garden miscellany that won't go in the attached garage. I also intend to restore an old vehicle or two there as well.
The tractor I will get first would be a smaller open station utility tractor, such as a Deere 4 series, one of the various LS XR variants (e.g. NH Boomer, CIH Farmall), a Kubota MX or grand L, etc. of 50-60 hp or so. It will pull an 8-10 foot pull behind bush hog and a 10-14' disc for field maintenance and I will also have a few miscellaneous implements such as a box blade and a tiller. All of that will get stored in the outbuilding. I may very well end up with a larger tractor and some hay implements in the future but that may be a while off if it ever happens, and that may be on a separate building on another piece of ground.
My experience with outbuildings is:
- A couple 19th century dirt floored barns. Not what I am looking for.
- A 20x20x10 concrete floored metal building at a previous house that the PO put up and I used as a woodshop. I prefer a basement shop as they are far tighter and the HVAC is already there.
- A 30x40x12 concrete floored metal building at my parent's property they have set up as a three car detached garage with overhead doors. This works well for that purpose and essentially I want to build a much larger version of that.
- Multiple 30x40 to 40x64 metal buildings with dirt/gravel floors end wall and side wall sliding doors for equipment storage and livestock. These are fine for a hay barn and livestock but not what I am looking for. The doors give a 24' opening on the widest one and we've never had trouble sticking any equipment in there, and my Dad's hay equipment is as big as anything I'd ever think I'd have.
I am thinking the following for the building:
- About 40' x 60' with a concrete slab floor. Sidewall height to be determined by door height, probably 14'?
- Construction could be either steel, pole barn, or stick built. I've had pole barns and stick built, and been in steel buildings, I don't really have a preference.
- Overhead doors on one sidewall. I think 12' tall should work as apart from a combine, my family has never had anything taller than that, and I don't see myself getting a combine, my ground is at most hay land and not really suited for row crops.
- I am not sure about the width of the doors. Anything I can see getting in the near future won't be more than 12-14' wide, and vehicles and trailers won't be wider than 10'. I see three options. One, a 16x12 and three 10x10 or 10x12s to make it a four-bay garage. Two, three 16x12s so I can stick implements in any bay and park trailers and vehicles in front of them. And four, two 24x12s to make essentially two "two car" bays.
- I may get a lift at some point for the restoration work.
- This will not be cooled, but may be heated. If so, it will be done with propane.
- I anticipate running a 100 or 125 amp line either from a multi-lugged meter base (as in one of my former houses) or as a subpanel from the house (as in another.) I can't see needing more than 125 amps. Loads would be lighting, an air compressor, pedestal grinder, a welder, and possibly a few miscellaneous metalworking tools if I need to get them (such as a small mill, etc.)
- Switch in the house controlling outside lights on the outbuilding so I can see to go out there when it's dark. I'd rather not do a yard light, had one at a previous place and I like it dark at night.
- Lighting will be appropriate for doing work, so about the same 100 fc as my woodshop.
- This is on rural land so there are no real restrictions.
- Budget is enough to do this correctly but I don't need to
Any input anybody has on the outbuilding design would be much appreciated.
