Hi Everyone, and please forgive my newbieness in advance!
I bought my current 1983 house 3 years ago and was impressed by the condition of the garage floor. It has no cracks, heaving, or spalling - but does have some light to moderate staining. I've been parking outside in the winter because I don't want to track in salt & mag chloride and have the floor start to deteriorate.
I borrowed a 2600psi pressure washer, bought a special wand attachment (see attached), Prosoco Light Duty Concrete cleaner, and Prosoco Saltgard penetrating sealer. I mistakenly thought the cleaner would lift off most of what you see in the photos, and I would simply apply the sealer and could begin parking there in the winter. As you can see, the cleaner wasn't strong enough....
Since it was going to take more work and heavier duty cleaner to remove the stains, I began to think about simply painting the floor with that new DrylokE1, or Rust Bullet. It would make for a nice uniform appearance, and would make sweeping easier - while protecting against the salt, etc. However, it requires thorough stain removal as well for it to stick. So for laughs I got a price to have a guy surface grind and epoxy the floor. It will run $665 for a 13' x 21' floor, which also happens to be about the same price as what I'd spend on the material alone for the RB. So I'm debating between the DrylokE1 (the much cheaper option) or the Epoxy. What kind of success has anyone had with the DrylokE1, and was it worth the prep time? I like the simplicity it offers, as to application and touch-up when needed. Plus, I wouldn't have to move everything out of the garage for 3 days. I could theoretically do half the floor at a time could I not?
BTW - the garage gets used mainly for lighter projects. Not a lot of automotive work, no welding (yet), and doesn't see much spillage of solvents, oils, etc.
Your opinions will be greatly appreciated!!
