Advice Needed on 8x8 Shed Construction
FordTruckWench
California
This sounds like a framing issue, not foundation. Easy fix to offset stud layout if the framer was paying attention.
The studs possibly needed to be in certain positions to match the sheathing edges. Anyway, the wall where I noticed this is a kitchen and there are four windows side by side. Well, correction, there are three windows side by side at minimum spacing (jack-king-jack studs I think), and a fourth with an extra two inches of spacing due to an interior wall. The window irregularity looks horrid from outside.
The roof framing on this house is all stick built. It is a crazy mix of hip and gable. And the builders got the pitch wrong on one piece.
southalabama
Brewton AL
As a reminder stated dimensions of products are not always exact dimensions. In fact they seldom are. As mentioned above industry standards vary. The industry standard on lumber has changed over the years. A 2x4 has shrunk over time.
Don’t over think an 8x8 shed.
mike93lx
Richmond, VA
A 2x4 hasn't shrunk over time though. We generally switched from using rough sawn to planed in construction about 80 years ago. Since then, it's been basically the same. Industry standard for a 2x4 is 1.5x3.5 and no one would argue that.
The starting point for the board is basically the same. Planed makes handling and finishing nicer.
southalabama
Brewton AL
Standard 2x4 wasn’t agreed upon till the early 1960’s.
Perhaps a bad example but the OP is so concerned about exact dimensions on an 8x8 shed I wanted him to know trade sizes may not be actual sizes. So he needs to verify and calculate accordingly.
southalabama
Brewton AL
All of these posts makes the point (I think) the OP should take heed since he’s so worried about exacting dimensions. 8’ studs aren’t 8’. 2x4’s are 2x4. So he needs to plan accordingly.
mike93lx
Richmond, VA
This mixing of terminology doesn't help. A stud isn't 8', but a 2x4x8 is 8'.
I don't fault him at all for being exacting. You have to experience some of this first hand to know where you can be rough and where precision matters. And trying to be as precise as possible can help errors from compounding and ending up in a spot where the error is so bad that you don't know how to correct
K
KPtexan05
Texas
Sorry y'all, didn't notice notifications that people were still replying to this thread!
As stated, dimensions aren't a huge deal to me, and I'm fully aware that a 2x4 isn't actually 2"x4", and stud length lumber isn't exactly 8' long. Stud length does not matter because this shed will have 7' walls at the top of the double top plate, so I'll be cutting all of the studs to length anyway. I'm not a novice woodworker by any means, but I just haven't framed a building that requires a relatively watertight envelope. I'll admit, I know I'm overthinking things, and at the end of the day this is just a small garden shed.
As mike93lx mentioned above, I do like to be as precise as possible when cutting lumber. Tolerance stacking is a thing no matter what you're making, and it's really easy to get within 1/16" on my miter saw.
I'm going to document my shed build in this thread and continue to ask any other questions here so as not to make a bunch of new topics. I think with the ideas y'all have given me, I can now design a relatively water tight arrangement where the shed meets the slab. Thanks for all the input!
mike93lx
Richmond, VA
I'd start a new thread....people don't read the whole thing and you'll get endless new comments about how you are wasting your time on precision
