Advice on building DIY hydraulic press
BikeRider
Queens, NYC
I'd like to build myself a smallish hydraulic press, something that could fit on a table and use say a 6-ton bottle jack. I realize that decent ready-made presses aren't that expensive, but cost is less a factor than size. I literally have no place to store a standard floor press. Nor do I really need anything this heavy duty. Just something that can press out the occasional stubborn hub from a spindle, or maybe straighten a slightly bent bolt, rod or flat beam, and then be stuck in a closet, or better yet, taken apart and stored in a box until the next use.
I've seen YouTube videos for such DIY presses, but even they seemed like more press than I really need. So I was wondering if anyone here had experience of or knowledge about how to do this. E.g. what kinds of steel beams and bolts should I get, and would I need to cut and maybe tap the beams myself? Do you know of links to decent DIY designs for such a press?
Alternately, are there reasonably-priced DIY kits one can buy with most or all of the parts (except the jack, which I already have)? Say, no more than $50-$60.
vpd66
Central Wisconsin
https://books.google.com/books?id=R...ge&q=popular mechanics september 1972&f=false
This is the press I'm currently collecting materials to build. I'm going to scale it up but you could build it has is or scale it down some if its too big for you. This is a very different design and is a very decent press. It uses a bottle jack and a leverage arm to up the tonnage output. The handle can also be rearranged and used has a manual press like an arbor press.Very smart design and could be made from scrap or drops. There is a Youtube video of a guy that has built one years ago out of scrap and loves it. Scroll to page 155 in the link. It is from Popular Mechanics September 1972.
