Bamacruiser98
- Joined
- May 1, 2024
- Messages
- 106
Good evening all, I collect several different things but old industrial lighting is up there as one of my favorites. I found this old Crouse Hinds fixture a couple months back in the wild and cleaned her up to look nice. That I wanted to wire it up to display in my garage but when I finished and went to screw in a bulb I realized the threaded piece of aluminum at the base of the socket was actually a part of the fixture. When I was going through the restore process it was fairly rough and had rusted due to the vapor proof globe being shattered at some point and that aluminum piece looked as if it was the base of an old bulb that also had been shattered so I stupidly removed it right rougher than I should have. Where might one find that piece? As you can tell in the pics I salvaged the bottom half of that piece but it's pointless bc now the bulb can't screw in. That was my first time seeing that set up or I would've know better. Any advice on where to find a replacement would be much appreciated.
