Advice on Garage Floor
Skylarkman
The most labor intensive part of my garage make over is proving more challenging than I could have imagined. After emptying the garage for the first time in 20 years, I can see the issues with my garage floor more clearly. Approximately 250 square feet and 70 yrs young, the slab is pretty ugly . Most of the cracks can be repaired with concrete repair caulking but some of the the stains are old and are not easily coming out . So far 2 power washing sessions have noticeably lightened the concrete ( first 2 photos)IMG_3982.jpgIMG_4030.jpg Mostly oil ( I think ) I’ve been using Zep concrete degreaser in the power washer and pouring the chemical directly on the stain and scrubbing with a brush. I am leaning toward the Rustoleum Rock Solid coating. but I know the floor will have to be much cleaner. The heat/ humidity will be increasing here in the north east soon , and realize this doesn’t help dry times . Any and all suggestions in prepping the floor are appreciated
SolarColumbia
Wisconsin
I'm wondering if there is any vapor barrier under that as I don't know when that practice came into use. If not, that could be a problem for putting down coating.
Garage Flooring
Grand Junction, CO
Skylarkman
Not familiar with vapor barrier’s used in concrete slabs. I’ve used a hammer drilling the floor previously and figured it’s around 5” in depth. What would I be looking for if I had one ?
SolarColumbia
Wisconsin
There would be a plastic sheet under the slab to prevent moisture coming up from the ground. If the concrete remains damp an epoxy coating may not adhere to the floor. You can purchase inexpensive calcium carbide test kits to see if the concrete is dry enough.
Skylarkman
Never had any moisture issues; good drainage in and around the garage.I read somewhere of a test to check the surface preparation that involved putting water on a few areas of the slab to see if the water beaded or absorbed into t the concrete. Would checking absorption in that mannered be a good test ?
SolarColumbia
Wisconsin
What you are describing is evaluating whether or not the concrete will absorb.
There is the method for testing dryness where you tape down the edges of 18" sheets of plastic in a couple of areas and after 24 hours see if any moisture is present underneath. It's not very accurate but better than nothing.
BigGarage
Just south of Detroit, MI.
My garage floor looked much like yours. Years of abuse and spilled liquids and paint overspray. I also used the Zep degreaser and scrubbed with a brush. Then I acid etched, rinsed, primed & painted. It all depends on how much you want to spend. I'm very happy with mine.
Dennis
Skylarkman
Dennis
What type of tiles did you use ?
Skylarkman
I vote for garage tiles all day long on that floor...
I do like the look of some of the tiles I’ve seen. Only con with the tiles is floor jack and jack stand damage to them
Crowbarman55
I have Racedeck flooring and love it. I find if you care enough to cover your concrete with anything to protect it and make it look good, you can just put a couple of pieces of plywood under your jacks and stands exc.. to protect the new floor too. I use some thin hardboard under mine. It works great.
I agree with others, Racedeck or similar tiles will work great on that floor.
Todd
rburke65
Canfield, Ohio
At 250 sq. ft., I would be a proponent of removing the floor and placing a new concrete floor. You could have a new floor for under 4 yards of concrete.
CJDave
Fairfield, Ohio
+1 on using the proper jack stands or the floor will dent. I have had no issues with my floor jack, or a loaded engine hoist or a loaded engine stand. Love my RaceDeck Free Flow. CJDave.
Derek91
Colorado
If the cracks are in plane, use ditra as an uncoupling membrane and run porcelain tile with in field expansion joints (schluter bwb). You can grind the floor and run a 12x12 tile for a more forgiving job. Then epoxy grout for the win.
RaceDeck1
Salt Lake City , Utah
Plastic flooring is about as expensive as ripping out the concrete and starting new.
Have you check the cost of concrete - It was already very expensive to have an old slab and proper slab installed,... Concrete is up 150% over since January. For around $3 to $3.75 ft, you can put RaceDeck over that floor and not worry about for many many years.. not to mention you'd be done in just a few hours
Armorpoxy
Numbers we are hearing with current pricing is that tiles would be 40-50% of the cost of replacing the concrete.
428PI
Peabody, KS
428Pi, is your screen name a reflection of the engine in your ride? CJDave.
Yes, my first car was a 65 Galaxie with a 390. My brother helped me overhaul it when I was a Sophomore in High School. It wasn't fast enough so I found a 68 428 police interceptor out of a Mercury in the junk yard. Overhauled it and stuffed it in there.
CJDave
Fairfield, Ohio
Cool story. My '69 Mach 1 has a 428 Cobra Jet. CJDave.
