Advice on Garage Size
jawmaw
Hi everyone. I have been reading many posts on this forum as I start researching the size of garage I want to build. I am limited to 800 square feet by ordinance but I am applying for a variance to build a 24x40.
If I am unable to get the variance I want to max out the size as close to 800 sq feet. I was thinking about a 20x40 or a 22x36. The overhead door will be on the gable end. I plan on using the front of the garage for parking only and the rear of the garage for a workshop area. Just general stuff no automotive work and no storage along the walls where the cars are parked.
I wanted to get some opinions on the width vs the depth issue.
We are going to eventually attach the garage to the house but not for a couple of years.
Thanks.
Falcon67
Merkel, TX
Check your ordinances - of you attach to the house now, you may be exempt from the limits because it's not a detached structure.
20 wide is the bare minimum for getting two decent sized vehicles side by side and opening doors. If one is a truck, then 22'. If both are trucks, then 22~24'.
tyjoja
albany ore
I have a 36' wide by 30' deep. with the gable on the door's side/front. something you might think about is buying scissor truss'es, I have 8 1/2' side walls, but easily have a 10' door in the center.
NUTTSGT
Northern Central Ohio
Hopefully you can get the variance for the 24x40. For good reason, the guys here will tell you to go bigger when it comes to a garage or shop.
Make sure whatever size you put up, fits with the size of the house and lay of the land.
J
jawmaw
Thanks for the comments. I will be restricted to 15' high so a second story is not possible.
I wish it was in the budget to attach it as the restrictions would then not apply.
