Jaymac7
Hello,
I want to insulate my garage door but I can't decide what will be the best way to do it. Unfortunately I have the type of steel (I believe) door that is flat and frameless on the inside. The pre-fabbed foam insulation kits therefore won't fit. I was planning on buying 4x8 sheets of foam board insulation and using a liquid nails adhesive designed for foam.
My main question is: 1" or 2"? The 1" is only rated R-6. Not much, but better than I have now! I don't know what the 2" is rated at, but higher than 6 anyway!
The concern I have is the weight difference of the 1" vs 2" and the adhesives ability to hold the 2" in place, day in, day out, through all the temperature extremes, especially when the garage door stays open for hours at a time!
Can anyone share thoughts/experiences/advice on the subject? Including the best tools & techniques to cut the corners down at then proper angle so the panels don't hit each other as the door opens?
thanks,
Jeremy
thanks,
Jeremy
