pdalton
I have a Craftsman 5HP/25 gallon air compressor (Model #919.15294 - so it's far from new) that -- for many years -- I've mostly used to air up tires & run a few air tools when working on vehicles, etc..
I've never tried using this (or any other) compressor to paint anything, but now I have several projects that require me to paint beyond what I think can be accomplished well (and efficiently) with just a brush or roller.
So far, the only thing I've changed on my compressor (about 10 years ago) has been to replace the original "winged" drain valve with a lever-operated ball valve to make it easier to blow out moisture after use. (I did this hoping to minimize tank rust). And I've recently purchased (and will soon install) an inline water separator.
What I would appreciate now are recommendations/suggestions in two areas:
A. Anything else I need to (or should) do at/on/for the compressor itself; and
B. Identify the reasonably-priced attachments / spray guns, etc. I need (or should have) to do the planned work [recognizing that these won't be for "pro" use, but that - like everyone - I hope for great looking results, but that, after these specific projects, I don't expect I'll be using them again very often].
[One important thing I'd like to know is whether HVLP is or should be a consideration for all or any of these projects and, if so, can I do that with my air compressor or must I buy a standalone HVLP-only unit, such as those from Earlex, Fuji, etc.?]
Here are my project "assignments":
**[Before painting all that siding, I want to first apply some sort of primer or waterproofer to the new siding pieces to help prevent them from getting water damaged over time, particularly along the bottom edges where it's obvious that "swelling" occurred in the past. So suggestions for products to use for this purpose would be appreciated, too.]
Thanks very much for any thoughts and suggestions.
Paul
- Painting ~10-12 sheets (4'x8', some partial) of new outdoor 3/4" plywood siding that will replace deteriorated pieces of the original (1984) siding on the house [at the same time I'll also be repainting the remaining old siding on that side of the house so it all matches]. **
- Sandblasting, then repainting several pieces of cast aluminum outdoor furniture (All were originally powder coated, but that's now peeling off in many places).
- Applying a finish (maybe stain, maybe paint) and then sealing (poly) ~4-5 freestanding cabinets I'm building.
Paul
