Looking for some advice from the resident experts here. I have a 2 car garage, home was built in '86 (San Diego) that I would like to have epoxied. I did a DIY job 10 years ago with some EpoxyShield from Homdepot. It lasted about 2 years before it started bubbling with little 'brown volcanos' of all over the floor. Looks like there may be no moisture barrier under the slab. I ended up putting a Versaroll vinyl covering down which has lasted until now. Note it is always wet under this vinyl.
Fast forward another 8 years or so and the vinyl has gotten stained up and the wife wants me to look into getting epoxy professionally installed. I got a couple of quotes locally and, while the quoted price for install is similar, there are differences in the products.
Opinions on where one is better than the other (particularly with my floor)?
Bid 1:
Moisture barrier from Koster (2 part Koster moisture barrier VAP I 2000)
Epoxy system from Arizona Polymer Flooring
Primer\base coat 550.
Install vinyl chips/MARBLE.
One coat of 400 clear.
Drill vapor ports
Install one coat of Polyurethane 100 UVR clear.
Bid 2:
Epoxy based moisture barrier (Kretus)
Polymer flake (Torginol)
Sika, polyaspartic top coat
Thanks for your help. 3rd time addressing this floor, want to do it right this time. Note bid 1 is recommending to drill many small vapor ports right through the slab. I never heard of this before, is it common (and advisable)
Bid 1:
Drill vapor ports
Bid 2:
