So I'm thinking of adding a couple extra outlets since the garage has one (its a rental house, so easy install removal would be good) and using some conduit and running outside the wall. Heres what I have to work with.
Would like to go over the left where the corner is. And then over to the right as well. 2 per run should be fine. Also would like a 240v right below the box but I think doing that inside the wall would be ok.
Thoughts?
Thoughts?
