Advice on stone adhesive
SRU1436
Bay Area, CA
I am building a new mailbox and thinking of using stone adhesive to attached the blocks to each other. The base will get a concrete foundation with first few blocks sitting in the moist concrete and inside center section will get concrete and rebar for the first few blocks as well. The remaining blocks will be attached with the stone adhesive. Attached is a link to something I’m thinking of using. And the photo is what I built (dry fitted). I’m still deciding on the cap in case someone asked about the top. I appreciate the advice.
Jinks
Daytona Beach
That'll do just fine, as will any good construction adhesive. I built a wall around some trees & a mound in my front yard 10/15 years ago. The stone had a back lip to keep them from slipping so everyone told me I didn't need adhesive. I'm stubborn, so I did it anyway. Nothing has moved.......... :dunno: Here's the "tree island"...IMG_0519_resized.jpg
KenC
oklahoma
Mortar will work as well. Cheaper, easier to clean off you hands and tools, and that will happen! I can't get close to adhesives and not get it on me! If you don't want exposed joints, going for dry laid look, then use thinset mortar like used for tile. Still cheaper.
SRU1436
Bay Area, CA
Looks good, I appreciate the info.
SRU1436
Bay Area, CA
Mortar seems like more work to me, and I’m only saying that because I tiled my laundry room (first time doing tile) and mixing and applying the mortar seemed like a huge pain. I do appreciate the info though.
