My workshop was originally built as a reservoir building. There is only one entrance, the garage door, and no windows or vents. The building is 40 feet by 40 feet, with 25 foot high ceilings (or 40K cubic feet)
https://www.garagejournal.com/forum/showthread.php?t=454133&showall=1
When the garage door is closed, the air stagnates inside the building and I end up with a stale and mildew smell. I have a 4 foot shop fan that I use to try to circulate the air but with only one exit, it isn't the most effective solution.
The challenge for me is that the walls are 18" thick rebar-reinforced concrete and not easily drilled to create ventilation ducts.
One idea I am thinking of is to install a large roof mounted exhaust fan. There is a manhole opening already cut in the roof that was the original access into the building when it was used as a reservoir. I can run this while I am in the shop with the garage door open to circulate fresh air while the shop is in use. This is the model I am thinking of:
https://www.globalindustrial.com/p/...bdd20gb-a-1-1-2-hp-115-230v-1-ph-5471-cfm-odp
A couple of questions:
Is this exhaust fan overkill or is 5471 CFM appropriate for a 40K cubic foot building? Are there other solutions that would accomplish the same objective easier and cheaper?
