Joe Piro
Question: How to wire a 12 volt pre-lube pump mounted temporarily for engine cleaning?
Info: My 94 Pathfinder V6 engine top end is full of sludge (from previous owner). I happened to have an external oil pump on hand which was originally designed for a pre-lube system that I never installed on another car. I have the valve covers off and physically brushed and vacuumed a lot of the deposits out (and cleaned the oil pan), and now I want to circulate mineral spirits to try to dissolve more sludge and clean up the engine. I can use a more aggressive solvent than often used for this because I will not be running the engine while circulating cleaning fluid (as I read a lot of people do).
I have put together a rig (See photo) with the pump, a knife switch to carry the current, and a remote oil filter adapter with a large WIX spin-on filter with no bypass. I have an adapter to **** oil from the oil pan, through the pump and through the filter and back into the 1/8" bspt port where the oil pressure sensor goes.
I was just gonna throw on some jumper cables from a battery to power this thing up, but decided that was sloppy and hazardous.
I need advice on a switch to wire it. I thought the knife witch was a good idea but now I don't think so... for one thing it sparks!
The instruction book specifies 30 fused amps at 12 vdc and to use 10 AWG wire. The pump is rated 1.5 rpm at 70 degrees F with 30 weight oil. I'm sure the pump is not designed for continuous duty as the factory encapsulated circuit module that came with it is set for 15 seconds at start up and 30 seconds at shut down if you're running a turbo. (Both times are adjustable.)
... Seems to me I should interupt both the positive and negative wires since the system is not grounded to the chassis.
So would that be a DPST Switch? I started looking at switch configurations and that's when I got really confused.
Thanks in advance for suggestions on how to switch and fuse this rig.
