R68GTO
After a lot of searching I have finally acquired enough aged barn siding and tin to finish out the inside of my garage. The 1st photo is a mockup of what I have in mind. The z-mold is screwed to the sill plate. Am I better off to go all the way to the floor with the z-mold or leave the stem wall exposed? On my interior walls, the sill plate is right on the floor. The mockup in my photo has the z-mold reversed so the longer leg is against the floor. Eventually I would like to install a porcelain tile floor, should I have the z-mold tight to the floor or should I space it up so the tile slips underneath? If I go to the floor, should I caulk that joint to keep water off the sill plate? Should that tall leg of the z-mold have a backer board to support it? What do the GJ experts think?
