AEG Power Tools
Monte
Germany
I bought a used, black, AEG SB2E-20 a decade ago and have used it extensively since then on a Maxion drill stand. The label says "Made in W.Germany", which dates it. Amazed what 850 watts can do to 8mm mild steel, it cuts swarf like far bigger pillar drills (which I do not have room for) and effortlessly produces perfect 10-20mm dia holes. I love that it has the speed adjustment on the top, which is perfect for drill stand applications - a design I haven't seen on any other hand held drill - and there's plenty of torque at the low RPMs required for larger tooling, thanks to a magnetic pick-up on the shaft providing feedback to the electronics. Sadly it has now developed a fault, which I'm hoping I'll be able to fix: it randomly jumps to full speed while running, which is absolutely terrifying when it happens, and of course renders it completely unusable. Popping the cover today I was surprised to see how advanced the speed control electronics are. Visual inspection reveals an overheated power resistor which I will replace, though I doubt that's the full story - would love to hear any suggestions on how to troubleshoot further!
Edit: Ok, yeah, it's not the (8k2) power resistor. I suspect it may be the U211B chip (a "Phase Control IC with Overload Limitation for Tacho Applications"), in which case I'm SOL; this part is long since obsolete and expensive if you can find one.
How do you like the drill stand ? Is there a deflection under load ?
PS: speed adjustment is available from Metabo for example (BEV 1300-2, BE 850-2, BE 600/13-2...) or Bosch (GBM 13-2 RE)
Vicks
Dubai
AEG (Allgemeine Elektricitäts-Gesellschaft AG) was founded in 1883 and went bust in 1996. Since then, it survives as a name only on low quality everything.
AEG (and AEG-Kanis) is a common name in the power generation industry with a reputation for their Turbo-Generators sets. Of course they do make a lot of other industrial equipment too. I wouldn't say that all of AEG equipment is "low quality". Maybe the small / handheld equipment line is....
Lomax
The drill stand is excellent, though not suitable for milling operations. Best stand I have owned.
Sorry, I probably wasn't clear about the speed adjustment; what I like is that the dial for setting the speed is on the top of the drill, where it is easy to access when the machine is mounted to a stand. I know lots of other power drills provide a speed setting, but this is usually integrated into the trigger, which makes it awkward to adjust when using a drill stand. I have not seen any other power drill, from AEG or others, which offers this convenience.
neophyte
Pennsylvannia
Metabo has a similar speed control dial on some of their higher end corded drills.
Monte
Germany
Thanks for the info !
Metabo....:
