Afci problem
barnowski2
I wired a new addition with 14-3 w ground and the rough electrical was approved by the county inspector along with the drawings. Now I'm trying to install the AFCI breakers as needed by county code, but with the multiwire 14-3 w gr wire I put in they are tripping as soon as I flip the swiitch. I ran a jumper neutrial wire from one braker to the other but didnt help. I installed regular breakers and everything worked good. Any ideas?? :shocking:
barnowski2
Yes, the 14-3 wire has 2 hot wires and 1 neutral wire. the AFCI want 1 hot, 1 neutral and there is only 1 neutral to use between 2 brakers, and it is tripping them both if it isnt set up correctly.
dw1
Ky
What type and brand of AFCI are you installing? Since you ran a 14/3 and have a multiwire branch circuit are you installing a multi wire AFCI
http://w3.usa.siemens.com/powerdist...t-breakers/2-pole-afci/pages/2-pole-afci.aspx
Just checking, not clear on what you put in, are you trying to use 2- single pole AFCI's?
dw1
Ky
Wylie types faster than me :rocker:, but... even though some breakers will fit several different panels, on the AFCI's I am pretty sure they are only approved to be installed in the exact same brand of panel.
pattenp
Virginia - USA
Just curious, but why in the world did you wire your circuit as a MWBC? Was it to save a couple of bucks on wire.
