After 55 years I found a use for this tool
bw77
Upstate NY
I was doing a tune-up and cleaning of an oil furnace, and I needed a long 1/4" magnetic
socket or nut driver.
I have a 6" Klein mag nut driver, but it wasn't quite long enough.
I know they make a really long one, but I don't have it.
I looked online for a 1/4 drive, 1/4 magnetic chrome socket and couldn't find one.
Then I remembered I have a set of Sears magnetic socket inserts that I bought around 1970
and never used. I put the 1/4" insert in a 1/4 chrome socket and it got the job done.
mcdye
funny, I ran across those not to long that my father had... kept them :)
ecotec
I will look for a few sets of those at garage/estate sales.
I have a set of 1/4” shallow impact magnetic sockets and some random deep.
I also have a few random deep 3/8” magnetic sockets with springs under the magnets.
I could throw these in spare sets of chrome sockets.
Beerhippie
Far NE Oregon
This is why we never, ever discard those tools we never use.
But a piece of aluminum foil works just fine, as do the suggestions above, all of which I've used at one time or another. Just the other day, I badly needed a magnetic screwdriver in #2 JIS--that would stick to SS screws. A dab of pipe dope on the tip was the answer.
Debcrow
New Mexico
A piece of electrical tape works just fine also.
If it's a 10 mm nut just braze it into the socket! Not only will it hold the nut where it will never fall out but you will never lose that 10mm socket because you will always know where it is! :)
cody1325
Southwest Virginia
Something similar with me.
I recently recovered my old screw starter from behind the workbench--seized up with rust from being missing at least a couple of years--Evaporust is being bought and new spares are being put on order. I was working on my 3D printer, and the set screws that hold the bed to the drive screw gears is stainless. Thus magnets didn't work. Ended up having to Super Glue the screw onto my driver to hold it.
Beerhippie
Far NE Oregon
I did that recently to remove a part from a vise. It was loose, but wasn't coming out, so a drop of CA glue on the tip of a piece of drill rod, a minute of silence and trying to have a steady hand, and it pulled right out.
I still need a Phillips/crosshead/JIS/whatever screw starter--and they're not only for starting screws, but for removing then from hard-to-access areas after being broken loose.
drmarkr
Tucson
Head over to Amazon and grab these...you can CA them into sockets when you need them. You can also use them as replacements in your nutdrivers when the original magnet falls out and gets lost. You'll find other uses for them over time, I assure you. $7.95 for the pack. 618nxvNeupL._SL1500_.jpg
johnre
Portland, OR
I have that exact set. And it has sat in my toolbox for 45 years, so you still have me by a decade longer.
It was part of the mid-size set that Sears sold me, I suppose so they could advertise a large "xxxx piece set" without a lot of cost on their side of it.
Beerhippie
Far NE Oregon
Magnets are wonderful and magical, but not much use when you work in a brewery where most everything is non-ferromagnetic stainless steel.
rlitman
Long Island
...Then I remembered I have a set of Sears magnetic socket inserts that I bought around 1970
LOL, I have that same set in my toolbox. Perhaps one day it will find it's calling just like yours.
rmanrman
How did you remember where those magnets were stashed for many years
I’m having trouble to find my 🚙 in a parking lot
