mayday0017
Who has an after cooler on your compressor? Show me your setup, share your thoughts....
Here are a couple I found...
B&M model 70266 (11″ x 8″ x 1½”) tranmission/engine oil cooler, an EBM Pabst model W2E250-HL06-01 230V AC fan (1160 cfm in open air) wired in parallell with the motor so when the motor runs, the fan runs and a Wilkerson model X01-04-M00 automatic drain. This fellow measured his compressor outlet temperature at 310F going into the aftercooler and 96F coming out. That’s a big drop! He says there are visible droplets of water in the plastic drain going to the Wilkerson. Note how he organized his plumbing to take the moisture down low and the air rising above.
Another compressor with a B&M transmission cooler and a 230V fan.
Very professional looking guard on this aftercooler. The automatic drain is from below again…
