Again porta-power - I made a mess!
manoweb
California
After I "fixed" the porta power pump this afternoon so that the pulling ram worked, I wanted to install a 10kPSI pressure gauge using a pressure rated tee. Theoretically very simple: remove the hose, install the tee, attach the hose, connect the gauge.
I removed the hose and it spit out some hydraulic fluid, a spring, a steel ball (and who knows what else? I did not find anything but I wasn't ready to catch anything, I didn't think it would be under some residual pressure)
See pictures below. I searched long on the Internet but the diagrams I've found do not show any spring like this. How do I put it together correctly? I am not in the mood to take chances as I plan to put thousands of PSI into this...
This is the portapower output, where I removed the 1/4" NTP hose
A better view of inside:
This is what came out (I hope I didn't miss anything, I wasn't exactly in the cleanest spot when I did this):
Detail of the hose fitting for reference:
sick467
Hughesville, Mo
Don't count me as an expert on this, but this is what I would do....I don't think you are missing anything. The ball goes into the pump first, then the spring. It acts as a check valve. The twist handle on the pump opens a port that will bypass the ball when you want to relieve the pressure that you have built up and the fluid bleeds back into pump housing.
The only thing I cannot determine is if the spring has a taper and would have to go into the pump a particular direction. The spring needs to touch and push up against the ball when the ball is touching its seat inside the pump. The pumped fluid will push past the ball (overcoming the spring pressure) building backpressure in the tool and line. This back pressure pushes back on the ball, pushing the ball up against its seat not allowing the fluid to flow backwards. The twist handle allows the fluid to flow back when your done. You can see how putting the ball and spring in the opposite way would defeat the purpose.
manoweb
California
Yeah it makes sense, I see the return port that is positioned "externally" to the place the ball would sit inside...
The spring is not 100% symmetrical but I do not really see a taper. I cannot imagine it should make a difference, now that I kind of understand the mechanism. I just have to check what the spring is pushing against to in order to act as a check valve now that I want to install a tee.
