I think I need an air chisel for a particularly vexing car disassembly job. I have a 2004 Mercury Marauder (like a Crown Vic) with the transmission crossmember press fit into two C-channel brackets on the side frame rails. It is notoriously difficult to remove. The factory installation apparently involves pressing it up into the C-channels (towards the floor pan of the car). The provision for removal is non-existant. Prying too hard will bend things.
I am thinking a wide air chisel in between the edge of the C-channel and the crossmember would be the least destructive way to loosen and spread slightly to get this out. Of course I have already used penetrating oil.
What is a good bang-for-the-buck tool to consider? I see that air hammers are rated from 5X to 9X, although I have no idea what this means - I am assuming 9X is more powerful. I don't know that I need the best or most powerful, but I also know better than to buy an inadequate tool.
Other uses might be chiseling of ball joint rivets, etc.
Thanks!
Thanks!
