Hi,
I am setting up an air compressor (puma pk6060V) , the wiring diagram that came with the compressor shows 2 hot and 1 ground, I looked where the ground is connected inside the pressure switch and it is connected to the actual tank.
I am setting up a 10G wire to hook up to the compressor , the 10G has 2 hots , 1 neutral and 1 ground, so where should I connect the neutral ?
or should the neutral connect to where it says ground on the pressure switch and eventually connects to the neutral in the electrical box , because the receptacle has 2 hots and one neutral and one ground all connected to the main panel using a double 30 amp breaker.
I am little puzzled by not seeing a neutral on the air compressor pressure switch.
